SONAX ProfiLine PolymerNetShield, Описание и отзывы по продукту |
21.6.2012, 11:53
Product: SONAX ProfiLine PolymerNetShield
![]() Article Code: 223 000/100 Formula Code: 2230 1396 Product Description: Surface protection with hybrid polymer technology for all painted surfaces. It protects the paintwork by means of a resistant network made of inorganic and organic components. Quick and easy to apply, it intensively freshens up the colours, and ensures a velvety smooth surface with an outstanding water drip-off effect. The ideal complement to paintwork sealing with SONAX Nano paint protect. Directions for Use: - Before sealing, the paintwork ought to be clean and fundamentally dry. Rest traces of moisture are not a problem. - Spray a little of the product onto an Application sponge and distribute over the paintwork, working crosswise. Always treat part sections (e.g. quarter bonnet). - Allow to flash off briefly, and then wipe over with a clean microfibre cloth and polish to a streak free finish. - Treat the next part section. Please Note: - Do not apply onto warm surfaces, or allow product to dry on. - If the product does dry on, or should the colours appear to be uneven, spray on fresh product and repeat the application. - Protect against extreme cold. Chemical Classification: Aqueous polymer emulsion with silicones Specific Data: Appearance: White fluid Density: 0.99 – 1.01 g/ml Viscosity: 15-20s (Ford cup 4mm) Packaging: 75 ml Aerosol can (223 000) 250 ml Aerosol can (223 100) Safety Data: See safety data sheet |
21.6.2012, 11:57
The process together with NanoPaintProtect is as follows:
-Apply 236 according our instructions -Leave the car at least 1 hour in a garage to be sure that NPP has reacted properly -Spray 223 in an ApplicationSponge and apply thin onto the paint -Treat only sections of about 1 sqm (e.g. half of a hood or less) -Wait no longer than 3 minutes before wiping with white MicrofibreCloth -If product is already dry, repeat application and reduce drying time; Do not try to rub intensively to avoid scratches! -To intensify colors you can do a second treatment if a absolutely perfect result is wanted. |
21.6.2012, 12:18
Переводить нужно?
Всем понятно будет? Кратко скажу, что продукт наносится через час после нанесения Нано лака. Наносится губкой или аппликатором и время ожидания не более 3 минут на ЛКП до вытирания и располировки. Принцип нанесения такой же как и у Нано лака (на небольшой участок нанести и располировать, например половина двери или четверть капота... ) При высыхании состава раньше времени и невозможности его располировки обработку на этом же участке повторить, но время высыхания взять меньше. Не трите с силой во избежание появления рисок и царапин. Для придания более вкусного и сочного цвета ЛКП обработку можно делать в несколько слоев, но это как говорится на вкус и цвет каждого. |
21.6.2012, 12:20
Это все пока теория.....
Я заказал себе образцы и скоро протестирую их лично. Только после этого смогу дать дополнения и коррективы к нанесению и применению. Пока только теория.... |
21.6.2012, 14:39
Лучше б сразу с переводом. Не все свободно владеют английским, в то числе и я.
Но что мне нравится, так это то, что Вы все сами тестируете и соглашаетесь с критикой (если она имеет место быть оправданно) Как говорится, респект |
21.6.2012, 17:57
21.6.2012, 22:39
22.6.2012, 11:16
А все так и есть. Сегодня собираюсь мьіть машину 2-х фазно, посмотрим на сход водьі. Alex ау, как там процесс На что похоже при мойке, а то на субботу уже два клиента на этот разрекламированный препарат приедут, вот и думаю, что им лучше нанести, толи сонакс воск премиум, то ли этот нет шилд, а може и твой подарок |
22.6.2012, 18:20
я с мобильника, поетому краток.
Нетшилд кошерно притемняет пластик. Сход пока класньій, лучше чем у Н7. Но тянет пьіль больше его. Сообщение отредактировал Alasar - 22.6.2012, 18:22 |
22.6.2012, 18:23
22.6.2012, 18:43
23.6.2012, 16:28
Поверх Н7 Также нанес на чистое ЛКП. Еще наблюдения: Нетшилд оставляет после себя тактильно гладкое покрытие, очень похожее, как после глины. Но не скользкое. Например, после бриллиант детейлера ЛКП более скользкое. Почти, как после лайта. Соответственно, пыли летит на детейлер меньше. Гидрофоб нетшилда на чистом ЛКП проверю на днях. p.s. Проверяю на машине, т.к. тестовая панель в покраске. И жду продаж детейлера! Им очень приятно и легко работать. Можно наносить прямо на мокрую поверхность. Сообщение отредактировал Alasar - 23.6.2012, 16:29 |
25.6.2012, 1:14
наблюдаю дальше...
Нашел у себя ядерный бесконтакт, который растворяет фольгу. Вообщем, брилиант дитейлер не держит его. Одна мойка и все. Финита ля комедия. Нетшилд после одной ядреной мойки держится. на днях проверю их количество для этого состава. |
25.6.2012, 2:23
Мультистар растворяет фольгу только в путь, как почти все бесконтакты
25.6.2012, 2:37
25.6.2012, 2:49
25.6.2012, 3:03
Мультистар мультистару рознь! Мультик от SONAX фольгу не разъедает! Он не наносит вреда ни пластику ни аллюминию... Это я к тому, что не такой уж и ядерный у Аласара бесконтакт. Если заявленный как сверхбережный (и типа поэтому плохомоющий) бесконтакт жрёт фольгу не стесняясь в 1000% рабочей концентрации |
25.6.2012, 10:32
Через 4 дня после нанесения приехал испытуемый автомобиль (на нанолак, которому уже месяца полтора, и четыре дня назад нанесен нетшилд).
Гидрофоб хороший, но данное свойство для первой мойки не столь актуально, так как и после дешевого воска при первых мойках вода слетает. Но как обычно Львов Киев, мошки тонна, отмылась без мочалок, в два этапа отлично. Однако стоит заметить, что всего сам нанолак за эти полтора месяца у меня мылся раз так 7-8 (частый клиент), и после нанесения нетшилда везде, кроме водительской двери (тестирую ж, позже домажу), при нанесении пены, на этой двери она более гуще, на остальном участке пена как на свеженанесеном нанолаке, еле держится. Ну и гидрофоб поинтересней, там где нетшилд. О гладкости, когда ведешь пальцами по чисто нанолаку и по нанолаку покрытому нетшилдом, или сразу трогаешь два участка двумя руками, то там где нетшилд гладкость раза в два лучше, на нанолаке пальцы сильнее тянутся по лаку. Но на небольшой участок, поверх нанолака и нетшилда нанес еще воск премиум, и гладкость на воске вне всякой конкуренции, просто в разы больше. Теперь о чудесах, когда еще полтора месца назад нанес нанолак на кузов, после второй мойки на зеркалах полностью исчез гидрофоб, ПОЛНОСТЬЮ. Подумал, что может его где ядреным чем смыли, но нигде окромя у меня не мылся. Я его опять там нанес. На следующей мойке тоже самое, нулевой эффект. Четыре дня назад нанес нетшилд и на зеркала, двойным слоем. ХЕРНЯ ЯКАСЬ, ТОТ ЖЕ ЭФФЕКТ, нулевой гидофоб именно на зеркалах. Вчера нанес на зеркала еще сонакс премиум воск, если он тоже куда то исчезнет, то начну верить в НЛО, бабаек, и о том что нужно делать отчисления в пенсионный фонд, что бы счастливо встретить старость (после того как бабушке орденоносцу труда платят пенсию подачку в 95$ , я за 12 лет ни одного отчисления в этот фонд не сделал и после регистрации там ниразу небыл, хоть и шлют письма). Может кто сталкивался, в чем хрень то такая, я не про бабушку и её пенсию, я про гидрофоб, куда он девается именно на зеркалах Крузака 200 нового? У этого же клиента обработана также Кемри новая и БМВ 5, и там всё окей. Загадка. Хотя он приезжает в мошке через которую эти зеркала и не видно, так её много, может она её ест, но блин не так же быстро, и чего она его не ест на бампере. |
25.6.2012, 10:45
Может кто сталкивался, в чем хрень то такая, я не про бабушку и её пенсию, я про гидрофоб, куда он девается именно на зеркалах Крузака 200 нового? У этого же клиента обработана также Кемри новая и БМВ 5, и там всё окей. Загадка. Хотя он приезжает в мошке через которую эти зеркала и не видно, так её много, может она её ест, но блин не так же быстро, и чего она его не ест на бампере. Видимо клиент большой любитель навалить по трассе хорошенько, причем регулярно. Пескоструем снимается все что угодно с зеркал. |
25.6.2012, 12:19
| Текстовая версия | Сейчас: 23.11.2026, 3:38 |
